adjusting front forks ???
#21
Quote Originally Posted by GIL with 1 L
I'm coming down next week and I'm going to leave trash and have my own personal drift session at all your spots
thats ok the drift car guys have trashed my local spot and all the spots down south are blown up from burnouts
Quote Originally Posted by !!A2K!!
gain more momentum when it compresses down. tire will stick better from transfer of weight. I never said they bottomed out either. diffrence between planting and bottoming out to where it thuds and makes creaky noises. plus its how i like my set up and I dont think its so rediculous.....I have absoultly no problem riding or doing long stoppies. ask OMR
you didnt have a damper when you were here so we never really got to roll far but ya i like my front to dive and stay down thats why i have my rebound set full hard but i do have my compression set kind of hard so the bike doesnt dive too much and bottom out
my front end doesnt bottom out cause i like to creep into my stoppies
style has alot to do with set up , when im doing really fast approach stoppies i pick up kind of slow so soft is fine but i still leave the rebound setting at full hard so the forks come back up slow but for short approach you can be alot more aggressive on your pop so a slower compression is better so the forks dont hammer down ..
do you always have to have the last word?
no... oh wait
true dat I run thicker to slow down my rebound never had no issues except for the occasional flip good tip add zip ties to your forks
you can gauge you settings then if im comming in 3rd gear pinned and grab the brake i want it to plant straight down that way I have a less chance of wash out listen to a2k he knows his stoppie game
Quote Originally Posted by tbozf4izzle
that does seem the way to go thanks
np homie hope you get them dialed in
took about a month to get mine perfect lol
also another tip wright down your settings as far as compression rebound clicks
and spring rate height also if you do change fluid viscosity wright that down to
might even go as far as the brand name because you get a diffrent feal with diffrent brands of fluid had to replace my seals and forgot all setting and fluid i was running
it was a nightmare when I got it back togeather
hope this helped yeah out
how have you been sir?
I've been good just trying to get back in shape lol kidney still goes in spasms
hurts like a mofo!!!
