Threads: 4
0
so when it come to endos do u want the compression softer so the front end will transfer the weight
more a less what im askin is whats the rule on dialing in your front end for the compression and rebound
Threads: 11
0
This is going to be interesting, alot of people have different opinions on this. I prefer rebound tight, back out the preload and start with the compression at the softest setting and work from there
Threads: 17
0
I get my suspension revalved bt RG3 Suspension.they change calving for a more progressive and controlled feel. That's the best option.
If you can't afford suspension tuning.. Then it's hard to say exactly how to dial in a bike because weight diffrences in riders and bikes and riding style.
Myself, coming from dirtbikes I prefer the more controlled feel. Some prefer the fork to slam down to bottom and ride basically on the bumpstop. (fully compressed)
The worst thing is there's do many people with improperly turned suspension and people who get bad advice of adding thick weight fluids and the like.
Threads: 62
0
Sending my forks to race tech......they build the best shit!!
I like for my forks to plant and stay there, no rebound or any other crap. I like them to slam down and sit lolol
Threads: 17
0
Thicker fluid creates more heat which causes differences from hot n cold suspension and increased chances of breaking down. All of that causes inconsistancy
The slam and sit at bottom that Racetech does is ridiculous in my opinion.
Just as ridiculous as someone saying try solid front forks.. With no suspension.
