Longer Clutch Cable for F4I??
^^^Winner! I remember that it would do that sometimes, nice call buddy
secure it somehow so it stays on the inside of the cap. thats what i did.
Quote Originally Posted by Machiavelli_Squid
No, just flipped 636 clips. I moved my grips all the way out, slid the clutch down and then i couldn't go full lock to the left, it would pull my clutch. So i routed it in-between my forks, it worked but after a couple wrecks it smashed the cable
Your not doing something right, I have a stock cable with 7 degree vortex clamps on, 2 inch rise dcp clip tubes, on a hohey tree with 954 forks. thats a 2 1/2 inch rise with fatter forks and my cable is on the outside of the fork tube.
Quote Originally Posted by Ethiopian
stock should work perfect, i run 12in bars in my clipons with stock cable on the outside of the fork with no biding issues. u sure its not catching on the rad cap when u turn your bars to the left?
I HATE when that happens! Grrrrr. Always happens as I slide into a drift and I tip over. Lol. I actually cut the protruding parts off the cap and its way better.
ran my cable threw the forks and zip tied it to the frame. seem to work fine.
i found that the stock cable is actually way long if you have clipons.
mine got all nestled up on one of the fittings for the overflow on the radiator, and it wore a hole in it and pissed hot coolant everywhere!
i run DB and stock worked. just play with it and re route it. If that doesn't work... then shit. lol
merry christmas
