Longer Clutch Cable for F4I?? - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: Longer Clutch Cable for F4I?? (/showthread.php?tid=21725) Pages:
Longer Clutch Cable for F4I?? - Diesel_Stunts - 12-21-2010 I need a new clutch cable for the rig, the stock is too short, but ive heard you can use a 636 cable?? Anyone doin that or hear of that? What year 636's? Longer Clutch Cable for F4I?? - SKETCHY - 12-21-2010 I think a 03/04 cable would work on a chopper its so long
Longer Clutch Cable for F4I?? - Ethiopian - 12-21-2010 would not work on my f4i, i had the adjuster by the clutch fully adjusted in and the slack on the end was still to much to work in the clutch perch. that was with a 04 636 cable Longer Clutch Cable for F4I?? - Diesel_Stunts - 12-21-2010 Hmmm..Thanks for the advice guys! Maybe ill just grab another stock cable, and route it differently??? Longer Clutch Cable for F4I?? - SKETCHY - 12-21-2010 you could try a CB600F cable. I wanna say its a little longer cause that bike runs beach bars stock. Longer Clutch Cable for F4I?? - Ethiopian - 12-21-2010 u trying dirtbars or somthing? Longer Clutch Cable for F4I?? - Diesel_Stunts - 12-21-2010 No, just flipped 636 clips. I moved my grips all the way out, slid the clutch down and then i couldn't go full lock to the left, it would pull my clutch. So i routed it in-between my forks, it worked but after a couple wrecks it smashed the cable
Longer Clutch Cable for F4I?? - NBstunter - 12-21-2010 just go to your local dealer and ask for a longer cable with the same amount stickout out on each end. any helpful parts desk worker will hook ya up no problem Longer Clutch Cable for F4I?? - Ethiopian - 12-21-2010 stock should work perfect, i run 12in bars in my clipons with stock cable on the outside of the fork with no biding issues. u sure its not catching on the rad cap when u turn your bars to the left? Longer Clutch Cable for F4I?? - Ethiopian - 12-21-2010 nevermind i routed my cable thru the forks, just looked hahaha. |
