636 choke mod explained
why not leave choke cable hooked up stock to the signal switch housing and activate it like that??? on a side note...sandbox at NDC customz is supposedly designing a "idle box" contraption that essentially does the same thing..adjusts your idle in stages like 1-5 or some shit...
Ask OMR, he did something like this.
Quote Originally Posted by Ethiopian
borne had his choke rigged up on his left clipon like ur talking about, maybe pm him.
Quote Originally Posted by SKETCHY
cool i will pm them
Quote Originally Posted by loogie
because the stock housing is soooo big...i want something with a much lower profile so i don't get my feet hung up on it
I know Shin can instantly switch from one idle to another. Saw him installing it at XDL Daytona. E-dub or Apex might be able to give some insight on this as well.
Quote Originally Posted by SIC J
thats exactly what i'm going for
you can spread the adjuster further apart to get more idle out of it , i added a spacer under the spring and i know tony prez made the roller part bigger for the same effect ..
another way to get it to idle higher would be to drill a couple small holes in the part that moves when you turn the throttle and bolt a plate to it so the roller can push it further ..
seen one guy use a ten speed bicycle gear change lever , they have notches so they stay where you put them ..
thanks roger for the help! i put a bigger roller on and took the shifter off my old mtb...it works perfect!
Quote Originally Posted by Zack Z
take a pic??
+1 on the pics...better yet post a how to thread in case anyone else wants superidlewhore mod....lol
