i heard that a few people are running the choke on the 636 i was wondering a few things.
i run my idle at 3500 and with the choke fully engaged it only goes up to about 5500. im looking to get around 6500 out of it...is there a way to mod the arm to move more to get those extra rpms?
i have the choke arm fully adjusted but when i have the choke engaged it wont stay at a high idle. the vibration from the bike causes the arm to go back down...thats another reason why i need the arm to move more so it can push against the arm and stay put.
what lever are you using on the bar instead of the stock housing?
let me know if it doesnt make sense because its kinda hard to explain
i know im not the first to do this...somebody has to have some info
Threads: 16
choke? why not the normal idle screw? 6500 revs makes for some nice 6th gear fast nohanders though!
da Liks
because i want to be able to switch between 3500 and 6500 with the flick of a lever so its almost instantly
Zack Z
theres a method to his madness I see. interesting idea
MikeOnTheBike
yes sir there is
Threads: 13
Zack Z
borne had his choke rigged up on his left clipon like ur talking about, maybe pm him.
Threads: 26
Likes Received: 1 in 1 posts
