What size rotor are people using for 05 636 rear wheel
#21
ive seen that but what is it exactly?
A gsxr rotor only needs a slight modification to fit.
I've got parts for busa rotors and 0304 front rotors. No modification required for the busa rotors and all you have to do for the kawi fronts is grind off the rivets.
If you're running radial calipers all you need is spacers.
Quote Originally Posted by noreen822
U have to go to the site and order what calipers ur running as a left and right
is it the same bracket just a little bigger?
I have the HoHey Big rotor kit on my 03 with the 05-06 Wheels and I was running a zx11d oem rotor. All I did was take my rotor bolts and put them on a mill and took off a little off of the top and they fit just fine no counter sinking needed and plenty of bite for the allen still. I then went to the EBC rotor and still works perfect.
I made sth like this
What rotor? Crazy the hub diameter is exactly the same.
What was the welding for?
gixxer k7 750. Inside diameter is exactly the same. Everything is the same, excepting bolt mounts - has 5 (4 at kawi).
to fit, I went to welder, next turner, and voilaaa :D
Mines a gsxr also
