What size rotor are people using for 05 636 rear wheel - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=9) +--- Thread: What size rotor are people using for 05 636 rear wheel (/showthread.php?tid=42807) |
What size rotor are people using for 05 636 rear wheel - B954Fl - 08-23-2012 I know people use a zx11 rotor but not sure what year cause i know theirs only 1 or 2 years that will fit 05?? What size rotor are people using for 05 636 rear wheel - Shockey - 08-24-2012 93-2001 zx11d. the "D" model is the only rotor that will bolt on, but depending on what HB bracket your going to run you might have to get the OEM zx11 rotor countersunk on the rotor bolts or the bolts will hit. IMO just spend the money and get the Galfer wave rotor for the zx11d and it is a direct bolt on with no mods. Only problem is i think its $150 What size rotor are people using for 05 636 rear wheel - B954Fl - 08-24-2012 Will it work with this bracket? I dont have 150 to drop on a rotor rite now. Brembo master 1 on the list of things i have to buy first What size rotor are people using for 05 636 rear wheel - B954Fl - 08-24-2012 Whats the difference between these 2 brotha?? Other than price http://www.ebay.com/itm/93-01-Kawasa...490bcd&vxp=mtr http://www.ebay.com/itm/93-01-Kawasa...f53e76&vxp=mtr What size rotor are people using for 05 636 rear wheel - Shockey - 08-24-2012 price is the only differance, between those 2. I bought my oem zx11 rotor for $50 and then it cost me another $50 to have the bolt holes countersunk just so i could run the rotor lol for some reason it wouldnt work on my NDC bracket unless i had it done. I should have just bought an aftermarket one . hohey carries the star big rotors and i think those are decently priced also.
What size rotor are people using for 05 636 rear wheel - B954Fl - 08-24-2012 Lol ya that sucks, so will those 2 fit with my bracket? What size rotor are people using for 05 636 rear wheel - Shockey - 08-24-2012 any aftermarket zx11d or oem zx11d rear rotor will work. What size rotor are people using for 05 636 rear wheel - B954Fl - 08-24-2012 Ok thanks alot man
What size rotor are people using for 05 636 rear wheel - Dr.MotoKawi - 08-24-2012 I think your kit uses a busa big rotor? Who makes that bracket? |
