ive searched but couldnt really find anything similar, what i got goin on is once i arrive at the lot unload the bike and start it up it sounds like its running off of 3 cyl, then give it about 15 seconds and it works its way out and runs fine! but as im riding if i come around and stall then take off again its got a really bad bog at low rpms, then if i let it sit for awhile (20 min or so) then go to ride again, the bike will just crank over and wont start
, i noticed today that when i go to start it the neutral light oil light and fi light come on, when it acts up and wont start the fi light doenst light up at all, im completely stumped on this one, any advice would be much appreciated!!!! thanks
oh ya the fi light always stays on btw cuz ive removed the butterfly valve!!!
you need to verify that there arent any other codes first
ya i figured that, im gonna try and see if theres anything else tomorrow
also i had an issue with a ground wire last weekend and we bypassed it at the lot so i can ride, gonna fix that issue as well, hopefully that will solve my problems all together lol
Sounds like fuel pump going out to me. I've been through 3 on my 06
SIC Nate
drain ur current gas and put fresh in also.
thanks everyone, i ripped the main wiring harness out tonight and stripped away all the stock covers and tape, what i found bummed me out, every single ground wire is melted in some way or another, the wire im talkin about is the black and yellow wire that runs all over the bike, im puzzled at this point
Nappy
thanks nappy but i hate havin that servo in there, i use the extra space to tuck unneeded wires and such
