06 636 bog and wont start!!!! - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: 06 636 bog and wont start!!!! (/showthread.php?tid=47124) Pages:
06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-04-2013 ive searched but couldnt really find anything similar, what i got goin on is once i arrive at the lot unload the bike and start it up it sounds like its running off of 3 cyl, then give it about 15 seconds and it works its way out and runs fine! but as im riding if i come around and stall then take off again its got a really bad bog at low rpms, then if i let it sit for awhile (20 min or so) then go to ride again, the bike will just crank over and wont start , i noticed today that when i go to start it the neutral light oil light and fi light come on, when it acts up and wont start the fi light doenst light up at all, im completely stumped on this one, any advice would be much appreciated!!!! thanks
06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-04-2013 oh ya the fi light always stays on btw cuz ive removed the butterfly valve!!! 06 636 bog and wont start!!!! - RYAN SMITH - 02-04-2013 you need to verify that there arent any other codes first 06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-04-2013 ya i figured that, im gonna try and see if theres anything else tomorrow 06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-04-2013 also i had an issue with a ground wire last weekend and we bypassed it at the lot so i can ride, gonna fix that issue as well, hopefully that will solve my problems all together lol 06 636 bog and wont start!!!! - SIC Nate - 02-05-2013 Sounds like fuel pump going out to me. I've been through 3 on my 06 06 636 bog and wont start!!!! - Shockey - 02-05-2013 drain ur current gas and put fresh in also. 06 636 bog and wont start!!!! - Nappy - 02-06-2013 Here is this as well.... http://stuntride.com/vbstunt/showthr...6-fi-light-off 06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-06-2013 thanks everyone, i ripped the main wiring harness out tonight and stripped away all the stock covers and tape, what i found bummed me out, every single ground wire is melted in some way or another, the wire im talkin about is the black and yellow wire that runs all over the bike, im puzzled at this point 06 636 bog and wont start!!!! - SIXDIRTYSIX - 02-06-2013 thanks nappy but i hate havin that servo in there, i use the extra space to tuck unneeded wires and such |
