Zx11 rotor
Zx11 rotor
\r\n \r\n I\'ve never had a real issue. I just rode it how it was. Wears down a little bit, but not to much.\r\n
\r\n \r\n HHD did mine, I assume any machine shop could do it.\r\n
\r\n \r\n \r\n \r\n \r\n
\r\n Originally Posted by PowdaB\r\n View Post\r\n
Squid question but how are you guys countersinking the rotor bolts so they don\'t hit the bracket? Thanks
I have a non-hohey bracket. I had to grind 1mm off the heads of my bracket bolts for clearance. I used the side of the wheel on my bench grinder.\r\n
\r\n \r\n Has anyone tired to use the oem zx11 bolts?\r\n
\r\n \r\n MVSbrendon may be able to help you....\r\n
Squid question but how are you guys countersinking the rotor bolts so they don't hit the bracket? Thanks
