Zx11 rotor - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: Zx11 rotor (/showthread.php?tid=33523) |
Zx11 rotor - DerekS - 10-14-2026 \r\n \r\n I\'ve never had a real issue. I just rode it how it was. Wears down a little bit, but not to much.\r\n Zx11 rotor - GAMstunts - 10-14-2026 \r\n \r\n HHD did mine, I assume any machine shop could do it.\r\n Zx11 rotor - MikeM - 10-14-2026 \r\n \r\n \r\n I have a non-hohey bracket. I had to grind 1mm off the heads of my bracket bolts for clearance. I used the side of the wheel on my bench grinder.\r\n
Quote: \r\n
Zx11 rotor - PowdaB - 10-14-2026 \r\n \r\n Has anyone tired to use the oem zx11 bolts?\r\n Zx11 rotor - SQUINTS - 10-14-2026 \r\n \r\n MVSbrendon may be able to help you....\r\n Zx11 rotor - PowdaB - 11-06-2011 Squid question but how are you guys countersinking the rotor bolts so they don't hit the bracket? Thanks
