11-05-2010, 08:09 PM
Hey Guys,
I've hit a wall with this new motor and need some help. The idle seems to drop whenever I'm in a circle on idle. NH's are impossible as-is basic NTH's and all other idle tricks. It seems to be getting worse the more I ride on this motor.
Here's what I've done and tried so far.
- put stock exhaust back on with valve
- put after market exhaust on with-out valve.
- put on previous throttle bodies
- changed spark plugs
- changed air filter
- used previous tank and pump (didn't have problems before with idle)
- checked idle cables and mechanism
- changed oil twice
- changed clutch plates and friction plates
- changed wiring harness
- changed CPU
None of these changes had any affect on how the bike idled. The motor that I put in had 20k miles on it but was not stunted.
Thanks for your help!
- changed oil twice
- changed CPU
- Do you guys have any suggestions as to what I should try next?
- Will getting the throttle bodies synced up help any?
- How about replacing the stator, LOL?
