2006 Kawi 636 - Idle Issue
\r\n \r\n Sync it maybe throttle or something like that i called ryan for the same reason he said its probably needs to be synced\r\n
\r\n \r\n kawis get tight valves all the time. Especially with 20k on that motor. try adjusting the valves asap!\r\n
\r\n \r\n have a real good look at all youre vaccum hoses make sure there routed properly and not split or leaking
\nalso check over all youre earth leads make sure there all on, tight and clean and check youre charging voltage\r\n
\r\n \r\n Great ideas guys, thanks!
\nI\'m pretty sure the vacuum hoses are good but i didn\'t check the charging voltage or try replacing the rectifier. I\'ll get the valves adjusted and throttle bodies synced.\r\n
\r\n Originally Posted by BIGJBEARS\r\n View Post\r\n
yep. \r\n
\r\n Originally Posted by jordo636\r\n View Post\r\n
\r\nI\'m pretty sure the vacuum hoses are good but i didn\'t check the charging voltage or try replacing the rectifier. I\'ll get the valves adjusted and throttle bodies synced.
If your rectifier was bad your battery would die.\r\n
\r\n \r\n Jordo, the first thing that came to mind is what El Sammo said about the vaccuum lines.
\nSecond thought, and this might sound dumb but do you have slack in your chain? If not that might be straining the motor during idle.
\nI need a hug.\r\n
\r\n \r\n I bought this tuner and will sync the throttle bodies tonight.
\n\r\n
\r\n \r\n still running like poop dumpsters??\r\n
yea, whats the story?\r\n
