01-13-2012, 07:31 AM
switch the two relays in the back. There identical, located on the back of the subframe on the right hand side
f4i fuel pump issue
01-13-2012, 11:24 AM
tried that, still strugglin with this shit.
01-13-2012, 11:27 AM
i went out and bought a voltage meter last night but cant even figure out how to use this thing
01-13-2012, 11:55 AM
Did u check ur ignition yet?
01-13-2012, 11:57 AM
http://stuntride.com/vbstunt/showthread.php?t=33803
Check this out, super easy and works perfect. Radioshack has everything u need
01-13-2012, 12:19 PM
Sounds like ur pump might of went out if u know someone with another f4i swap them and see if that ur issue
01-13-2012, 12:23 PM
my buddi hooked me up with another pump, still no prime. how do i jump it and see if it primes.
01-13-2012, 01:07 PM
http://stuntride.com/vbstunt/showthread.php?t=33786
Check out this wiring diagram, might help you out. You may be able to jump the pump, but that is a crappy fix to the problem. A guy that used to ride here did that, and he had to flip a switch and his pump would continually prime till he switched it off. Much better to find the actual cause if you can. If you can, u should print out the wiring diagram there. I made it, and it has helped me out quite a few times.
01-13-2012, 01:24 PM
Im guessing youve probably already checked the fuses. Do any of the fuses pop when you try and turn the key? If so then the harness is grounding out somewhere. Id just pull the whole harness out, untape it all, look through it, retape it, add some heat shroud, test it and put it back in. It ill take you a few hours but atleast u'll know you wont have any issues anymore.
« Next Oldest | Next Newest »
