0
so i cant get my fuel pump to prime, the relays click when i flip the kill switch, the bike cranks, i checked the pink wire coming from the ecu, and as well as the ignition. i checked the rectifer to see if anything was fried but everything is good. i have the green wire jumped to the red on the main wire harness that connects up to the headlight and that connection is good as well. any help would be appreciated
0
my fuel pump had some how grounded out and fried the ground wire going from the fuel pump to the wire harnes, i fixed that wire then dropped the bike and the fuel pump wouldnt prime again but its not that ground wire. i even switched fuel pumps and still no prime
Threads: 3
0
Can u crank from the starter button. I had that problem, when I opened the starter button a wire had came loose. it won't prime.
Threads: 3
0
Also check the main fuse. I had that problem also. It's right on the positive side of the terminal.
Threads: 8
0
My ignition went bad and I had that problem. Did the keyless ignition mod and the bike fired right up
0
have u disconnected any plugs from the harness and put them back together wrong?...my pump wouldnt prime(bike turned over,but no prime from pump) ) because there r two plugs that r identical and will plug into each other...check the plug that comes from the left handle bar switch. theres another plug from the harness thats identical,...switch the plugs....once i did that my fuel pump came on and bike crank...
