Threads: 9
http://www.hoheydesigns.com/store/in...roducts_id=108
so is this what we need or the actual rotor spacer? or both?
if so where do we get the rotor spacer?
wanting to do this conversion in the next couple weeks so want to get everything i need!!!
Threads: 36
Originally Posted by WiseGuy
Yes this is what u need. U keep the stock 03 on one side and use the HHD spacer on the other. The 05- present wheels def look better but that 03-04 swingarm is something off of a dirtbike
Id change it all out to 05 and up
Threads: 9
i jus hate to have to buy another DC set up for the 05 swingarm cause i am jus getting used to the one i got, plus kinda broke, lol... rowdy ill let u know what i decide to do about that swingarm
Threads: 9
Originally Posted by nj636
or get to cuttin
is this what needs done if i were to get the hohey spacer kit? and a rotor spacer is still needed as well?
Threads: 6
i used an FTI bracket with hohey wheel spacer kit..
if you don't want to cut up your nice FTI bracket & have time; find or make a spacer for the rotor.. a little more involved than cutting the inner tabs off the FTI bracket
i've been running my setup all year with no problems
Threads: 9
HoHey's spacers are measured for HoHey's bracket, so it's not exactly what he needs.
Threads: 10
what is the advantage to this swap, anything other than looks??
Threads: 6
i did it just because i like the 05+ wheels better.. if i did it again i would do the 05+ swingarm along with the wheels
Threads: 39
The wheels or swingarm? obviously they look night/day better than the 03/04 stock 99 dirt bike garbage but the wheels are way lighter which translates into less rotating mass which equals a "lighter" feeling bike.The 07/08 swingarm is longer so it feels more stable in drifts and pretty much better anything stunt related.I did it for looks and realized how much better it is.Hands down best stunt setup IMHO is 03/04 636 with steel frame and 07/08 brakes/suspension.
Threads: 9
Someone told me the other day the 03/04 wheels where lighter than the 05/06 wheels, but I'd never looked into it. Do you happen to know the weight on the front/rear for each?
