(636) 05 rear wheel on 03 swingarm - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: (636) 05 rear wheel on 03 swingarm (/showthread.php?tid=29280) Pages:
(636) 05 rear wheel on 03 swingarm - Villa76 - 06-30-2011 Use the 05 spacers and axle or use the 03 hardware? Have both. Thanks in advance. (636) 05 rear wheel on 03 swingarm - WiseGuy - 06-30-2011 i jus had a thread about converting to 05-06 wheels and front end... 05 spacers with 03 swingarm, if u are running an FTI bracket it wont line up tho... (636) 05 rear wheel on 03 swingarm - loogie - 06-30-2011 you need e HHD spacer kit or make your own. (636) 05 rear wheel on 03 swingarm - loogie - 06-30-2011 Quote:
(636) 05 rear wheel on 03 swingarm - WiseGuy - 06-30-2011 thanks loogie! (636) 05 rear wheel on 03 swingarm - Villa76 - 06-30-2011 Figures. I do have the fti dual cal. (636) 05 rear wheel on 03 swingarm - WiseGuy - 06-30-2011 i know i had the same moment as u... we r gonna have to find some of those spacers, or get some 06 swingarms...
(636) 05 rear wheel on 03 swingarm - old man roger - 06-30-2011 you use both on the right side , one big spacer one small spacer and if you have the fti caliper mount you can make a spacer to move the rotor over to the caliper (636) 05 rear wheel on 03 swingarm - nj636 - 06-30-2011 or get to cuttin
(636) 05 rear wheel on 03 swingarm - GIL with 1 L - 06-30-2011 Trade ya for 05 swingarm |
