Threads: 10
Thanks for the help/input guys, ordering a ape cct tonight from the ape site.
Gonna keep my fingers crossed that this also helps with this bog issue.
Threads: 39
old man roger
stock exhaust will give you the best low end and syncing the throttle bodies can never be a bad thing but i have seen a few people with 636's with no low end and no one has really come up with a good reason why , i know thats not a great answer but
had the same problem on my 636 i had a few years back,if you remember i posted a thread..in my case it ended up being a tired motor that burned a little bit of oil then alot then blew up at the lot overheated on a limiter burnout
fresh motor solved the bog
