Threads: 30
I have an HHD Dual caliper with a 4 piston adaptor for my HB, stock FB... I am wanting to upgrade to the big rotor kit... do I need to buy another bracket for my 4 piston or just a bracket to space my stock footbrake caliper? or Both? And a large rotor ofcourse...
If anyone has one laying around that they want to get rid of PM me... Just want a bot more feel on the brakes...
thanks in advance
-Matt
If you want more feeling in the fb go up to a 4-piston footbrake.... it's magical. I have WASTED ankles and had a real hard time modulating the stock hard fb pedal and after I went to the 4-piston it gave the pedal more play and feel. It's awesome
Threads: 30
Want more feel on the HB not FB... Want to go big rotor , but need some info...
Threads: 26
Likes Received: 3 in 2 posts
doesn't feel much diff to me..
Threads: 36
U wont get anymore "feel" out of a big rotor kit. Change ur HB mastercylinder for that
Threads: 30
I have a magura
Threads: 36
Originally Posted by ADBZ Matt
I have a magura
Yea so?
which one?
The feel is all in the master. 13mm has the squishy feel with a ton of bite, but u really cant drag a 13mm and be as smooth w a single 4 piston setup. A 16mm on the other hand u can drag smoother, but doesnt have that inital effortless bite as much as the 13mm will. I switched to a 16mm Billet on the Kawi and I like it.
Threads: 30
Yea so?  which one?
hmmm good info... I have the 13 MM it is almost too squishy and the bite is gone... maybe i need some better brake pads... It is bled very well. I am certain of that...
Threads: 35
Likes Received: 2 in 2 posts
thanks in advance
-Matt
The f4i is totaly different bracket and adapter brackets
the 636 is the same main with different caliper brackets, the up grade is like 234 on the site
Threads: 30
but from what I am hearing its not really worth it... if someone else thinks differently LMK
