Big Rotor Kit Question - Printable Version
+--- Thread: Big Rotor Kit Question (/showthread.php?tid=21698)
Big Rotor Kit Question - ADBZ Matt - 12-20-2010
I have an HHD Dual caliper with a 4 piston adaptor for my HB, stock FB... I am wanting to upgrade to the big rotor kit... do I need to buy another bracket for my 4 piston or just a bracket to space my stock footbrake caliper? or Both? And a large rotor ofcourse...
If anyone has one laying around that they want to get rid of PM me... Just want a bot more feel on the brakes...
thanks in advance
-Matt
Big Rotor Kit Question - Raider - 12-20-2010
If you want more feeling in the fb go up to a 4-piston footbrake.... it's magical. I have WASTED ankles and had a real hard time modulating the stock hard fb pedal and after I went to the 4-piston it gave the pedal more play and feel. It's awesome
Big Rotor Kit Question - ADBZ Matt - 12-21-2010
Want more feel on the HB not FB... Want to go big rotor , but need some info...
Big Rotor Kit Question - J Blox - 12-21-2010
doesn't feel much diff to me..
Big Rotor Kit Question - ROWDY - 12-21-2010
U wont get anymore "feel" out of a big rotor kit. Change ur HB mastercylinder for that
Originally Posted by ROWDY
I have a magura
Originally Posted by ADBZ Matt
I have a magura
Yea so? which one?
The feel is all in the master. 13mm has the squishy feel with a ton of bite, but u really cant drag a 13mm and be as smooth w a single 4 piston setup. A 16mm on the other hand u can drag smoother, but doesnt have that inital effortless bite as much as the 13mm will. I switched to a 16mm Billet on the Kawi and I like it.
Yea so? which one?
hmmm good info... I have the 13 MM it is almost too squishy and the bite is gone... maybe i need some better brake pads... It is bled very well. I am certain of that...
Big Rotor Kit Question - MiNi GuineA - 12-21-2010
thanks in advance
-Matt
The f4i is totaly different bracket and adapter brackets
the 636 is the same main with different caliper brackets, the up grade is like 234 on the site
Originally Posted by MiNi GuineA
but from what I am hearing its not really worth it... if someone else thinks differently LMK
