01-11-2009, 05:47 AM
Here is a quick how to for the stuntex oil pickup mod for the f4i's. Hope it helps some of you new guys out
Step 1: take off headers, radiator(optional)
Step 2: Drain oil
Step 3: remove oil pan (might have to tap around the sides to get it to pull off after removing bolts)
Step 4: you will see the oil sucker (the big funnel looking thing in the middle)
-pull it out, there is a rubber bushing that goes with it
Step 5: Remove the rubber. Place your stuntex washer key on the top of the sucker
Step 6: You will see where the original sucker goes there is a keyway where the piece sticks in, since you are flipping the sucker around the stuntex washer key will be replacing this.
You will bend up the stuntex thing so it sits in the keyway
Make sure that it sits in the keyway
Step 7:The stuntex metal gasket will sit in between the rubber and the stuntex washer/key. There are little marks in the metal that the teeth sit in.
Step 8: put some gasket sealer on either side of the stuntex metal gasket(not alot) and put it all together
bolt your oil pan back up and your all good to go make wheelies!
Step 2: Drain oil
