Stuntex Oil Pickup 4 F4i - install FOR DUMMIES =) - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: Stuntex Oil Pickup 4 F4i - install FOR DUMMIES =) (/showthread.php?tid=3964) Pages:
Stuntex Oil Pickup 4 F4i - install FOR DUMMIES =) - StrictlyStunt - 01-11-2009 Here is a quick how to for the stuntex oil pickup mod for the f4i's. Hope it helps some of you new guys out Step 1: take off headers, radiator(optional) Step 2: Drain oil Step 3: remove oil pan (might have to tap around the sides to get it to pull off after removing bolts) ![]() Step 4: you will see the oil sucker (the big funnel looking thing in the middle) -pull it out, there is a rubber bushing that goes with it ![]() Step 5: Remove the rubber. Place your stuntex washer key on the top of the sucker ![]() Step 6: You will see where the original sucker goes there is a keyway where the piece sticks in, since you are flipping the sucker around the stuntex washer key will be replacing this. You will bend up the stuntex thing so it sits in the keyway ![]() Make sure that it sits in the keyway ![]() Step 7:The stuntex metal gasket will sit in between the rubber and the stuntex washer/key. There are little marks in the metal that the teeth sit in. ![]() ![]() Step 8: put some gasket sealer on either side of the stuntex metal gasket(not alot) and put it all together ![]() ![]() bolt your oil pan back up and your all good to go make wheelies! Stuntex Oil Pickup 4 F4i - install FOR DUMMIES =) - tangelo6 - 08-07-2009 hey i have brand new never installed stuntex pic up for f4i if anyone needs one... 50 bucks plus shipping sorry to thread jack Stuntex Oil Pickup 4 F4i - install FOR DUMMIES =) - vtecthisvr6 - 09-24-2009 i have a srad 750, just blew my motor, any1 have any ideas for me? Stuntex Oil Pickup 4 F4i - install FOR DUMMIES =) - StrictlyStunt - 09-24-2009 sell the srad ![]() Overfill your oil like a half quart Stuntex Oil Pickup 4 F4i - install FOR DUMMIES =) - dlish - 09-29-2009 i FILL MY F4I SO THE OILS AT THE MID OF WINDOW WHEN ON THE SIDE STAND Stuntex Oil Pickup 4 F4i - install FOR DUMMIES =) - Ryan Lanier - 09-29-2009 Oil pick up for the new 07-08 r6? After about 1.5 mile wheelies the oil light kicks on, with and extra quart in it Stuntex Oil Pickup 4 F4i - install FOR DUMMIES =) - stefko - 11-07-2012 Do you guys know what metal the gasket is made of? Alluminium? and whats the thickness ? 1mm maybe ? Stuntex Oil Pickup 4 F4i - install FOR DUMMIES =) - J Blox - 11-07-2012 metal. Stuntex Oil Pickup 4 F4i - install FOR DUMMIES =) - stefko - 11-08-2012 Yeah, but what kind? Aluminium, Steel ? And how thick it is?
Stuntex Oil Pickup 4 F4i - install FOR DUMMIES =) - StrictlyStunt - 11-08-2012 I do not know the thickness, I can measure next time I have mine apart. But they are high quality CNC machined aluminum. |
