Threads: 28
Did this for Mini Guinea about 2 months ago now. We had a deal worked out with payment which there was some confusion and now he isn't responding to calls, texts, FB messages, or FB wall posts. I'd really like Mini to pay for it but in the end I'm sick of looking at the tank. It is internally vented using the OEM overflow tube which is hooked up to automotive gas line and has a one way check valve at the end. The valve allows air in as the gas goes out. (in theory this tank has never been used) The inside of the tank should be coated using POR-15 or some other tank liner since the majority of the top is mild steel and it may rust on the inside.
Threads: 45
interesting... looks like you put some good work into it
Threads: 47
Threads: 12
How much if you spray the por-15
Threads: 28
if you buy the kit i'll do it for nothing. i just dont wanna come outa pocket anymore for this tank.
Threads: 12
Threads: 28
Threads: 12
Threads: 28
Threads: 26
Likes Received: 3 in 2 posts
