03-04 Flat top gas tank $300 shipped. - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: General Category (https://stuntride.org/forumdisplay.php?fid=3) +--- Forum: DURTY's corner (https://stuntride.org/forumdisplay.php?fid=69) +--- Thread: 03-04 Flat top gas tank $300 shipped. (/showthread.php?tid=38029) Pages:
03-04 Flat top gas tank $300 shipped. - Paul - 03-29-2012 Did this for Mini Guinea about 2 months ago now. We had a deal worked out with payment which there was some confusion and now he isn't responding to calls, texts, FB messages, or FB wall posts. I'd really like Mini to pay for it but in the end I'm sick of looking at the tank. It is internally vented using the OEM overflow tube which is hooked up to automotive gas line and has a one way check valve at the end. The valve allows air in as the gas goes out. (in theory this tank has never been used) The inside of the tank should be coated using POR-15 or some other tank liner since the majority of the top is mild steel and it may rust on the inside. ![]()
03-04 Flat top gas tank $300 shipped. - SQUINTS - 03-29-2012 interesting... looks like you put some good work into it
03-04 Flat top gas tank $300 shipped. - B-rup - 03-29-2012 That shit is siiiiiick 03-04 Flat top gas tank $300 shipped. - BLEED - 03-29-2012 How much if you spray the por-15 03-04 Flat top gas tank $300 shipped. - Paul - 03-29-2012 if you buy the kit i'll do it for nothing. i just dont wanna come outa pocket anymore for this tank. 03-04 Flat top gas tank $300 shipped. - BLEED - 03-29-2012 How much is tge kit? 03-04 Flat top gas tank $300 shipped. - Paul - 03-29-2012 http://www.por15.com/US-STANDARD-TAN...oductinfo/TSG/ 03-04 Flat top gas tank $300 shipped. - BLEED - 03-29-2012 So an 8oz will be good? 03-04 Flat top gas tank $300 shipped. - Paul - 03-29-2012 yeah i think so. 03-04 Flat top gas tank $300 shipped. - J Blox - 03-29-2012 subscribed.. |
