brakes dont bite.. - Printable Version
+--- Thread: brakes dont bite.. (/showthread.php?tid=20405)
Pages: 1 2 3 4
brakes dont bite.. - MVSBrendon - 10-14-2026
\r\n \r\n Or you just bring the bike up to my house and we fix the problem.... Told you that last week.....\r\n
brakes dont bite.. - TheFBomb13 - 10-14-2026
\r\n Originally Posted by MVSBrendon\r\n View Post\r\n
lol yea i know but i fixed them... and your in VT you told me to come saturday.. i cant go to your house if your not there .. well technically i can cause your my dad and all\r\n
brakes dont bite.. - GIL with 1 L - 10-14-2026
\r\n Originally Posted by TheFBomb13\r\n View Post\r\n
i thought the all stunters were cheap?!?! ahaha
cheap and proud ,\r\n
brakes dont bite.. - da Liks - 10-14-2026
\r\n \r\n Shakira-Brakes don\'t bite\r\n
brakes dont bite.. - sQuiD FigHTer - 10-14-2026
\r\n Originally Posted by da Liks\r\n View Post\r\n
thats because i beat them off of her \r\n
brakes dont bite.. - 02gsxxr - 10-14-2026
\r\n \r\n I have the same problem cant even do burnouts none the less endo\'s... i\'m switching my handbrake to a gsxr or R1 radial master plus i have a clearance issue with my throttle sticking cause the F4i master is fucking huge\r\n
\r\n Originally Posted by 02gsxxr\r\n View Post\r\n
i heard gsxr radials are garbage \r\n
brakes dont bite.. - mdub4life29 - 10-14-2026
\r\n Originally Posted by Doodle\r\n View Post\r\n
brake fluid will ruin the pads,as will fork fluid..if either have came in contact it will make them not as effective..swap the pads and brake fluid...a brake overhaul is never a bad idear.
true once they are saturated no wash will take out the fluid. i know this seems janky but only way ive found works is pull pads out and get a torch and heat them up and it will evaporate the fluid. i know it is not the right way but pads are expensive and were all trying to save a buck all of my friends and i have done it and still have no problems. o and brake clean the rotors and and lightly scuff them with scotch brite or light grit sand paper\r\n
\r\n Originally Posted by mdub4life29\r\n View Post\r\n
i used scuff pad and it worked mint!\r\n
brakes dont bite.. - TheFBomb13 - 11-10-2010
searched for it but got nothing..
i have an f4i with a 600rr front end(pads, rotors, calipers) but stock f4i front brake master and lines..
my brakes dont bite hard enough.. i can't do endos or even get the brakes to lock up.. should i just got new brakes??
the rotors are straight and the pads still have a lot of life left.. and the brakes are bled fine i have good pressure in them.. am i missing something? can i clean them somehow?
