Threads: 17
\r\n \r\n scotch brite your rotors in a circle pattern.
\nare you sure you dont have air in the sytem? I know a bunch of people who rocked the stocker f4i till they had money for a good one but they could stoppie no problem on them.\r\n
Threads: 23
\r\n \r\n brake fluid on the pads ? are the pads from the f4i front end ? if so you may just need to let them seat to the new rotors ..\r\n
\r\n \r\n \r\n \r\n \r\n Originally Posted by Naarden\r\n  \r\n \r\n scotch brite your rotors in a circle pattern. \n \nare you sure you dont have air in the sytem? I know a bunch of people who rocked the stocker f4i till they had money for a good one but they could stoppie no problem on them. \r\n \r\n | \r\n
Im positive i dont have air in the system my lever is rock solid
\nand are you talking about the pads that you clean dishes with its green kinda looks like scuff pads?! lol i didnt clean the rotors only the pads
\r\n \r\n \r\n \r\n \r\n Originally Posted by old man roger\r\n  \r\n \r\n brake fluid on the pads ? are the pads from the f4i front end ? if so you may just need to let them seat to the new rotors .. \r\n \r\n | \r\n
i thought i had brake fluid on the pads so i cleaned them off
\nthe pads are the ones i got with the front end im guessing they are for the 600rr.. can you use f4i pads on a 600rr front end??
\nand im positive that none of the brakes are new at all..
\nthe brake lines and master cylinder are from the f4i
\nthe rotors pads and calipers are from the 600rr ..\r\n
Threads: 23
\r\n \r\n same pads and if you did get brake fluid on them and washed it off before you used the pads thats all good but if you get them hot with brake fluid on them then it\'s gonna be a while before they ever work good if at all\r\n
Threads: 16
\r\n \r\n on the cleaning part: how long were the pads "dirty" and how did you "clean" them??? did you clean the rotors too?? with brakecleaner!! you can sand the pads evenly, clean them out with some bakecleaner, clean the rotors and then ride and let the pads set..\r\n
Threads: 13
Likes Received: 2 in 1 posts
Likes Given: 4
\r\n \r\n \r\n \r\n \r\n Originally Posted by TheFBomb13\r\n  \r\n \r\n \n \ni thought i had brake fluid on the pads so i cleaned them off \n \nthe pads are the ones i got with the front end im guessing they are for the 600rr.. can you use f4i pads on a 600rr front end?? \n \nand im positive that none of the brakes are new at all.. \n \nthe brake lines and master cylinder are from the f4i \n \nthe rotors pads and calipers are from the 600rr .. \r\n \r\n | \r\n
the pads are only the same if you have the 03-04 600rr calipers, if your got the 05-06 inverted frontend they will not work.\r\n
Threads: 11
\r\n \r\n All that stuff was off my 05/600rr and I had no problem rolling 400\' off a 200\' approach. It\'s air, your lines, the master, or the nut on the seat. Pads we\'re not even broken in yet\r\n
Threads: 11
\r\n \r\n All that stuff was off my 05/600rr and I had no problem rolling 400\' off a 200\' approach. It\'s air, your lines, the master, or the nut on the sat. Pads we\'re not even broken in yet\r\n
Threads: 4
\r\n \r\n brake fluid will ruin the pads,as will fork fluid..if either have came in contact it will make them not as effective..swap the pads and brake fluid...a brake overhaul is never a bad idear.\r\n
\r\n \r\n \r\n \r\n \r\n Originally Posted by da Liks\r\n  \r\n \r\n on the cleaning part: how long were the pads "dirty" and how did you "clean" them??? did you clean the rotors too?? with brakecleaner!! you can sand the pads evenly, clean them out with some bakecleaner, clean the rotors and then ride and let the pads set.. \r\n \r\n | \r\n
took all the pads out and washed them in water with some purple power or whatever with a wirebrush no i didnt clean the rotors ... what grit sand paper do you suggest using??
\r\n \r\n \r\n \r\n \r\n Originally Posted by GIL with 1 L\r\n  \r\n \r\n All that stuff was off my 05/600rr and I had no problem rolling 400\' off a 200\' approach. It\'s air, your lines, the master, or the nut on the sat. Pads we\'re not even broken in yet \r\n \r\n | \r\n
dont take this the wrong way .. you also told me the forks didn\'t leak
\ni dont understand why it would be air, or my lines, or my master when they all worked mint before i put this front end on.. the lever is stiff feels exactly how i had it before.. it probably is brake fluid that got on it im just wondering how i can clean them up so i wont have to worry bout buyin some new ones till next season..
\r\n \r\n \r\n \r\n \r\n Originally Posted by Doodle\r\n  \r\n \r\n brake fluid will ruin the pads,as will fork fluid..if either have came in contact it will make them not as effective..swap the pads and brake fluid...a brake overhaul is never a bad idear. \r\n \r\n | \r\n
yea the calipers seemed pretty grimey im probably gonna rip em apart when i get a chance..\r\n
