Threads: 28
0
whats up guys been reading everywhere trying to figure out if u can upgrade to the big rotor if u got the hohey streetfighter bracket. can you? also found on here somewhere that CB500, CB900 Hornet, XLV600 Transalp rotors fit the F4i, they are 240mm instead of 220mm. can I run one of those rotors with the streetfighter bracket and not have to cut pads?
0
NDC for big rotor. Streetfighterz bracket for stock rotor. I don't know about the 20mm larger rotors fitting, but I remember everything is tight on those so I would just run the stock rotor. Can you even find SF brackets in stock anywhere? I haven't looked in a long time.
Threads: 28
0
Yeah I ordered it off of hohey.com and I'm not sure how the power will be on the 4piston and a r6 master I don't want to have my finger getting tired fast. I am using an adaptor with stock piston and it works ok learned circles with it but I need more power. I know the Magura is the easiest pull but I'm Gona try to run my r6 master for now. I also was thinking of running the 4 piston linked with my foot caliper for more power for e cheap. What do you think?
Sent from my iPhone using Tapatalk
0
The r6 master with a four piston will have plenty of power, no need to worry.
0
Yeah, it's a 16mm I believe so like Larse said, no need to link them.
Threads: 28
0
Ok
Threads: 28
0
Thanks
