Threads: 4
0
This is probably a stupid question, but does anyone run a stiffer front fork spring? If so, is it noticeable in an endo? And would you think its a necessary uprade? I need to change my fork seals and bushing, and I am justifying the $100 for new stiffer springs. But don't want too if it's not needed... any feedback on this would be badass...
Sent from my SM-N900P using Tapatalk
0
Yea it'll come up easier tighter the spring rate
Sent using nanobots
Threads: 4
0
I'm about 210...
0
You might try your preload and rebound adjustment's they could give you a weak spring feeling and will change the reaction your bike has to the front brake
Sent using nanobots
Threads: 4
0
Are you running what racetech recommends for your weight or just a little heavier than stock?
0
Just a little heavier than stock ... changed em just cause I had it apart the stock ones worked just fine if I fine tuned preload and rebojnd
Sent using nanobots
