Threads: 3
So I've been on here for a couple months getting info for things I should do to my 636 so far I've found a bunch of good info still trying to figure out things for a handbrake setup this is my first stunt bike I races motocross my whole life and I'm getting into stunt riding I hope I pick it up as well as motocross anyways here is my bike so far any advice on building up my bike would be appreciated
Threads: 67
my cage sick cage bent after one crash lol and it wasn't that bad of a crash
Threads: 6
All of my atown cages and parts have held up nice and always bolted on/off easily, if your sick cage is toast I would consider atown to replace it. (Link below)
As for the swingarm the 07-08 zx6r bolts up with out having to cut or grind anything but I believe you need to use the 07-08 pivot block and links when you switch also. I would stay with the 05-06 swingarm they don't look that ugly and you know your shock/linkage/chain and everything else will work with it just fine.
Threads: 3
Ya sick cages suck I wrecked once and it was not bad at all I had to cut it off my bike all the hard wear was bent and whole throttle side of my cage was bent up so bad I couldn't get to the bolt so I ended up cutting it off my bike I also got a sick round bar and it was a biotch to put on I think this time around I'm goin with Atowns cage
Threads: 3
My cage after one small wreck hard wear is also bent to hell had to cut the cage to even get it off
Threads: 3
Finally dented my tank today first one I have ever done
Threads: 3
Dinted my tank a little more needed more of a lip
Threads: 3
MY BET IS you didnt tighten the cage properly down the bottem because SI cages are a top quality cage and it takes a huge huge huge crash to cause that.
Threads: 22
burnoutnut
I hope you are being sarcastic
Threads: 22
^^^this I have their clipons and love them
