0
I need to replace the engine in the 05 R6, if I want to buy the same bare engine 03-04 without injections etc will all fit if interspersed with other parts of the engine 05? Do I have to buy the whole engine 03 - 04, along with all the accessories?
Threads: 4
0
Im currently repalcing mine with one from an 03 and i just switched over everything over from the 05 (throttle bodies, etc)...from what ive been told and read the bare motors will fit in any year r6
Sent from my SCH-R530U using Tapatalk 2
Threads: 8
0
Either like Swampy said swap over the TBs and fuel rail from the '05 to the 03-04 motor. Otherwise you will need the other ECU. '05 is the only year with that fuel tune and the 2mm oversized TBs. 03-04, 06-09 R6s motors run shitty on an '05 ECU. But if you just throw a whole motor in no swapping things around got to have the other ECU. Everything else is the same.
