0
I don't run the servo with the stock exhaust and manage to get by... If you want I'll make you a little circuit you can plug in to replace the servo and keep the lights off. They're like $50 if you buy them online, I'll do $25 shipped.
0
Thanks man and I'll keep that in mind but have read without it you loose some bottom end? It was just an idea I've been tossing around in my head.
0
Honestly I'm not really sure... The servo was broken on my bike when I got it so I just pulled it out to save space. I tried messing with the valve by wiring it in various positions to add back pressure, but that just seemed to kill the power so idk. I really want to ditch the super heavy and ugly stocker and fab up a custom exhaust system so I'm not going to sweat messing with it.
0
ive got a custom midpipe with eyelid welded on the inside. my bike runs and sounds strong. yoshimura can
0
762SPR will set ya up... Your timing gets turned down 3 degrees when the FI light is on. I'd just buy the mod from him. The servo is more work to rig up than 25 bucks worth of time imo...
0
Hoping he will! I went to listen to the new sound ad the massive bog before the rev was pretty disappointing!
