I recently ordered zero degree clipons for my build. The more I think about it, the more I'd like to try out mx style bars. So my question to you guys is...Is there an aftermarket triple for mx bars that can replace my stock triple? Or is this just wishful thinking?
Threads: 28
UUUMMMMM On what bike???
WHEELIE
07 zx6r. My bad I didn't think it mattered if a company sells them, I assumed they would carry triples for more than 1 model bike.
Threads: 28
1time
Well if you had a F3 or a an F4i or even a Ninja 250
vs a 929 or a 636 or a ZX6r (with a 50MM Fork) then you would see why
I asked.....
Hohey sells them .... Or you can Drill and Mount your own
risers...
Threads: 28
WHEELIE
I asked.....
risers...
yeah, I'm not sure how familiar you are with the 07-08 zx6r, but the triple is cast aluminum. It looks really brittle and thin, so I don't want to risk welding or drilling them to make them weaker than they are. I will check out hohey. Thanks for the heads up.
Threads: 6
Sick innovations has a badass top triple too.
If you drill the triple: fill the pockets on the underside with jb weld or something like it before drilling. Then use big washers between the nut and jb weld when mounting the risers
Threads: 66
Running a hohey triple on my bike, super solid. Hear good things about the SI one too
Threads: 28
Larse
