0506 zx motor in 0304
ok ok ok iv used the search and googled my ass off.. i want to try and make fit a 06 636 motor into a 03 frame i might be picking up.. i know the mounts are off by a little bit. but do any frame builders or fabbers know exacty how far off it is? and if i could cnc a few brackets to fill the gap???
i dont want to spend the money to buy a frame if i dont need too. just wondering if it can be done.
i have an entire 06 that the frame snapped on to use for my 0304 hybrid. just wondering if i can make it work for cheep
Originally Posted by Swanny
it will be way to much work. By the time your done you could have goten a 04 motor. i kow the 05 head will fit on an 04 motor. Its the rear mounts that are off and they are the most important ones
Originally Posted by hypermike-gba
oh ok, i was under the impression it was the front that were off. thanks
Swanny hit up Billie for Badass frames.. he's got a 06 motor in a 03/04 great guy could probably answer your questions..
Balancetheory is his name on here
