I promise, I searched. 14mm nissin master?
Hey guys,
I know you're all very into making sure people use the search first, and I tried. I couldnt find the information I'm looking for. All I found was every saying to use a 16x18 brembo.
My question is, how are the 14mm nissin master cylinders? I can get a whole handbrake kit from the local dealership for 300 dollars even. My friend had them order it in, and decided he wanted a different set up, so they just want to get rid of it. The only thing, is I'd have to trade or sell the 4 piston adapter probably because its for 03-04 636, and I have an 05. How is the feel of the 14mm master cylinder for a 4 piston caliper? Im tempted to buy it, but I dont want to make a mistake if it wont be any good for street riding.
Thanks guys, you're the shit!
-Rob
no idea personally... but I would expect a medium to soft feel with a single 4 piston on the rear... in the middle of 13 and 16...
I definitely don't want a hard biting hb... being that I will be learning handbrake with it. I'll probably just go for it, and if it sucks, whatever, I'll sell it on ebay or some shit. Anyone else try one?
probly be a bit harder feel than a 16
you'd probly like a 16 better
Radial master? What else is in the "kit"? Where was this ordered from?
Post pics if you can. 14mm would be softer then a 16, little harder then a 13.
I have a feeling this is a non radial master.
If its a non radial your better off just using a flipped 0304 636 master. I believe those are 14mm and you'll save a shit ton of cash. But I think that will be still to soft for streets with a four piston.
Originally Posted by lee majors
Wow please tell me this whole sentence is a typo
I'll find out today what it is exactly. its just the master, lever, brake line, and dual caliper adapter in the kit.
pretty sure this is the same one, but ill stop by honda and find out.
http://www.hordpower.com/index.php?m...products_id=17
