0
so i spun a rod barring and it scored my crank and rod... so i was wondering if i bought a used crank and used rod and pistons would i have to have them balanced or would i just be able to slap it together and be fine??? or should i just buy a used motor and just put that in ..... second if i do buy used would 600rr parts fit in the 600f4i same year??? that might be a stupid question but i was just wondering bc im finding a lot of parts for the 600rr not that many for the f4i thanks for the help... ps i have a 2003 f4i stunted out
Threads: 8
0
I'm sure there are different bearing codes so you would have to wait til you got the new crank in hand and figure out what main and rod bearings you need. Like with the Yamahas there are numbers stamped on the motor case, numbers on the rod endcaps, and numbers on the the outter must crank web. by using the numbers on the crank web and the numbers on the case you get the journal bearing code, using the crank web and the rod end cap number you get the rod bearing code. That make sense?
0
for a cheap quick fix that could last 1 hr or 40k miles, u can throw in a used un-damaged crank and slap a used rod with new rod bearing. but in a perfect world, there are markings on the rod and cases that require specific bearing sizes (when assembled new) your actually suppose to plasti gauge the plane bearings (crank bearings/journals) but from what i seen in the different size crank bearings is not a real measurable amount. you will need to buy a new head gasket also.
0
sounds like a bigger head ache then its worth rebuilding then buying a motor out a wrecked bike.... im good but no professional mechanic
