Threads: 6
0
Ok putting on a si round bar on my f4i. Want to make it look as flush and as clean as possible without snapping the tail. I just need someone to post a picture of theirs that is clean looking and they dont have a problem with it. Just need a reference point. Thanks.
Threads: 9
0
guess and test. put the tail fairing on and see where the bar sits. then cut little by little. i find if you cut precise and hit the bar, u still messing up your tail fairing. so give it a little more slack back
0
Str8JDM hit the nail on the head. I just pulled everything off. Mounted up the bar loosely and slowly hacked away with a dremel and using a marker to mark potential spots. Just keep putting the tail section back on and off til it fits how you like.
Cutting little by little is always the best bet.
