My Piece Project
My Piece Project
So I got this for a steal. Payed $2000 for it this past Friday. Only has 16k miles on it. I knew the two previous owners so I know it wasn't abuse and it's been sitting for over a year.
This is my other 636.
As of now I'm unsure of which to stunt out. I have pretty much everything except a cage as I'm unsure of what to go with. I have a tygershark on my f4i and love it but it's a different design for the 636, and it's broken 3 motor mounts on 3 different motors on my homies bike.
This will be a street piece stunter. Not sure of size of sprocket for it so any tip and input from ya streets killas is welcome. Also is any opinions on a scheme or whatever.
I'll update as I go.
Thanks.
Almost there. But rad mounts on frame are off. Fans bang into sensor and motor. Any ideas?
Rotate the cam sensor 90� degrees or so or add a spacer on bottom mount between bracket/motor but not too much or fairings will rub
Rotate the cam sensor 90• degrees or so or add a spacer on bottom mount between bracket/motor but not too much or fairings will rub
I already rotated the sensor from when I first installed the rad cage. But I'll give the spacer a shot tomorrow.
Inbox me your number broski.
bike looks sick. you're sticking with full fairing? and why the steel frame? you crack yours or just wanted one?
Quote Originally Posted by zprt00
Thanks. Yea I want to stay FF with this one. And there was absolutely nothing wrong with my stock frame. I just jumped on the steel frame bandwagon. Thought I was getting a good deal on something that has just turned out to be a headache.
A few more tweaks and It's golden. Took it for a test run for the first time after starting the built. Runs strong and can't even tell the difference in frame weight.
that bike looks sick as hell man, good job
man lol if I ever went ff, this is how I want it to look, good job, bet it was dramaaaaaaaaa!!!!!
Quote Originally Posted by Steven_John
Quote Originally Posted by YardSaleStunts
Thanks fellas. Yea I wanted to stay with something simple but neat and clean look. I'm not into them crazy neon colors that most are doing. Nothing against a them but it just not my thing. A few headaches and disappointments on the way but I guess the final results were worth it.
