Brembo RCS???
Brembo RCS???
Decided that the Magura is not for me... cannot get used to the feel of it and finally gonna drop a fair amount of coin on a new hb master....
Who has ran and what is your opinion of the Brembo RCS??? Either the 15mm or 16mm??
Was debating trying the 15mm but after talking with HyperMike I decided to probably go with the 16mm (clutch), anyone have any other info to add to this topic????
Run a 16x18 Clutch side, non rcs. Cheaper and the same performance. I would be willing to bet you wont be switching the valving
I run the clutch side RCS jake, 16x18 love it but it was spendy, I just like the folding lever piece of mind I guess. Can't go wrong with either!
Originally Posted by StuntBikeJake
I've heard this more times than I can count...good reason why we haven't offered Magura
Originally Posted by zeus_r6
You know regardless of which brembo I snag Ill be coming to you good sir!
much appreciated
i got the 15mm RCS and it rules.
the rcs clutch side 16mm looked like it has a funky lever made to pull all the way into the bar.
Originally Posted by anarchist35
What caliper are you running it.on?
nissin 4 piston (black f4i caliper)
