Threads: 12
ive put in a couple sessions totally dedicated to sitdown circles and the best i can get is a horseshoe shape. my psi is high and i can roll first gear wheelies straigtline for as long as i want, i just cant turn what so ever. i get to bp and and start turning and just cant hold it. when i do get a horse shoe shape it is wide as fuck. got any tips?
try staggards first maybe?? i find goin straight is harder now than circles lol. just practice man... keep the front end high and it dips pretty easily...
Threads: 12
i can do staggards pretty well its just when i put both feet on the pegs. i lean in the direction im trying to spin but i just get off balanced
thinkin about it more... i am almost always counter steering when i do them. steering on the fiddys helps alot
Threads: 12
now when you say counter stearing you mean what direction you are pointing the front wheel?
If you want to go right for example, you push right, meaning the wheel if pointing at the opposite way of you turn.
Threads: 67
Keep your chest square with the bars. Don't let off, instead stick your inside foot out until you can find the sweet spot.
Threads: 12
alright. should i lean forward or keep my arms completely extended?
Threads: 6
I kick my knees out to help with balance while circling .02
I remember really using my legs when first learning them on the 50. If you watch videos you'll see guys stick their whole leg out sometimes.
One thing you could try which even helped me on my f4i was putting the inside leg on the ground. With the 50 I imagine you'd have even more control. It helped me get the circles a lot tighter doing that too. As you practice start trying to lift your leg off the ground once you start getting a couple circles in a row. You'll eventually just leave it on the peg the whole time.
As far as how far to extend your arms, I'd try whatever keeps your torso pretty much perpendicular to the ground. That'll be a good place to start. Make the circles look good and effortless later.
One thing, what gear and speed are you working on with the sitdowns? With high pressure and goin pretty slow that thing should try to circle on its own.
