06-03-2012, 02:18 AM
I am at it again. My snuggie bike was dying a slow painful death, so instead of patching it up I decided to go for a rebuild. I am starting with my cage. If you recall I built my current cage using lightweight square tubing. It was a last min. effort to start riding my new bike. I figured it to last a month, but I would have been happy for a day. After 4 months of beating it to hell trying to learn circles, I am stoked to report that it only has one part in need of repair. I have decided to wipe my mind of any paradigms I may have about cages, and look at it from a different angle. This is what I have come up with...
Most of the cages I see now are super strong very high-tech and for the most part well manufactured. They also cost a shit load of doll hairs. My new cage isn't for the pros that already have everything and an iron man. This cage is for the guy keeps breaking shitty parts. If your outfitting a virgin bike you will need a cage, and, 12 bar, if your a bigger fellow you will also need a sub-cage. I have designed and started fabrication of a steel exo-skeleton. This cage replaces both passenger brackets and pegs. It replaces the rearsets with 1/4" cross braced plate steel. It's main job is that of any cage, to protect the motor and frame. This shares the load of multiple impacts scenarios over an arsenal of mounting points. Not to mention it acts as a sub cage brace that has an integrated 12 bar. I will be posting pics of this build as I go. Tonight I built the right side mounting plate. It uses the swingarm pivot bolt as a mounting point, both rearset bolt holes and both sub-frame holes. Everything will be built from this plate. The subcage and 12 bar will be tied to the cross brace between the rearsets and the plate triangulating the enitre rear half of the bike.
SHITTT!
My phone went dead tonight so no pics today I will be sure to snap some on monday!
SHITTT!
