Hey gonna be switching my si street cage to an impaktech one after work tomorrow just want a quick install guide. Do I need to put a jack under the engine so it doesn't sag once I take out the bolt from the old cage? also only one side at a time b.c of the previous reason? thanks for any help
Ohyea its an 06 636
Threads: 39
No the engine wont "sag" coz its got 2 rear engine bolts that keeps the motor from doing so.
Threads: 47
Just did mine. Pulled all the bolts and then put the cage on and it went on just fine. Just make sure you got the metal spacers in the right places before you install to make it easiest
Thanks I ended up doing it last night I got anxious, went all together pretty easy.. can't wait to ride after work today... high of 50 degrees!
Threads: 3
garcia2389
And rainy though
... I'm workin in Joliet today, def gonna try and ride if it dries up
Yea im hoping it dries up too
