636 broken headlight tabs...repair idea
\r\n \r\n i cannot view the photo but i have been thinking of something like this as well... there has to be a way to reinforce these and make all of the crappy ones usable again...\r\n
\r\n \r\n Ya Sandbox\'s is like that with lil aluminum 90 brackets..I run a stealthstay and dont bolt my headlight to it...The headlight being mounted to the upper and the upper being tied into my stealthstay is SOLID...No offense but the johnnyp stays are totally inferior and the design makes 0 sense IMO.Only benifit is being aluminum instead of steel but still junk IMO.\r\n
\r\n \r\n i know man i hit up stuntfarm to grab a stealthstay instead and just sell the johnny p and the price was just alittle more than i expected,....as much as i wanted to say F it and just buy it, i still got a bunch of other parts i need to get this bike stunt worthy and im already running low on funds so thats why i figured ill try fixing the headlight first...i got the johnnyp for almost $150 less than what the stealthstay cost so thats why im rockin it.
\na stealthstay is DEFINITLY going to be one of those "later on down the road" mods though\r\n
\r\n \r\n and wiseguy the picture is just a pic of a regular 636 light without the metal added just to get an idea of what i was explaining...i havnt seen one with the metal mod done but i feel like it shouldnt be that hard to do and apparently im not the only one to think of it if sandbox is rockin it too\r\n
\r\n \r\n cool, i got rid of my johhny p and have the Steathstay on my 04 now and i blew a few tabs off my headlight when i got hit by a car at low speed on my stunter... i just beat it back straight with a rubber mallet, but havent tried to remount my headlight so not even sure i need this since loogie says his doesnt even mount to the stay... i will check it out this weekend and let you know, but yeah Steathstay for the win \r\n
\r\n Originally Posted by ny450\r\n View Post\r\n
so i just got a johnny p stunt stay for my 03 636 and realized its useless because both of my top headlight tabs are broken and thats where it mounts to...didnt know they were broken previous owner mustve done it.
\ninstead of having to sell the stay and get something else, or buy a new headlight, i wanted to try to repair the one i got since its fresh other than the tabs and i actually like the johnny p alot (and got it cheap).
\nbefore i go out and buy the shit and waste my time attempting this, i figured id run it by you guys to see if you think its worth the try, or if it sounds like it could work...too many of my good "ideas" tend to turn into fucked up wastes of time and $ lol.
\nidea: instead of epoxying or gluing the tabs back on, which didnt work for shit cause the prev. owner tried it, i figured id think of an alternative that could possibly make it even stronger than normal.
\nheres what the top of the headlight would look like:
\ni was thinking i could leave the tabs off and buy some sheet metal and cut a peice long enough to fit across the top of the light...somehow mount the sheet metal to the top of the headlight plastic, i would assume with some self tapping sheet metal screws....then mark where each tab was and make some little 90 degree metal tabs, and then screw them into the "new" headlight surface which would be metal, drill a hole in the tab and bolt it up to the stay...then add a bunch of extra screws where it needed them to keep it tight and strong.
\nthink this would work? seems like it should do the trick, only thing i wouldnt be too sure of is if the sheet metal screws would hold in the top of the headlight plastic?
\nopinions?
You actually dont need those 2 tabs to mount my stay, there are 3 more mounts located in the front...That go right through the headlight housing itself...I did that for this exact reason, the stock mounts break off so easily...
\nPeople talk alot of shit about my stays these days because 5+ years after I designed it and started selling them, there are finally some other decent products on the market! Well thats great but where were this people in 04/05, when I was forced to make my own because everything else was garbage? It took 5 years for other people to make a comparable product and your going to knock my shit, and praise them? Not to mention it looks like most that have bad things to say about my stuff are either friends with another company, or sponsored by them.....I dont get my friends to come on here and big up my shit, or put other companies down...That shit is weak!
\nEveryone is entitled to their own opinion, but give me a fucking break...I made that shit years ago, have sold over 300 of them world wide...Majority of people are more then happy with them.....And when I designed them this was your only option on the market...905 Racing charged me $250 for this peice of scrap metal....So at that time it was ahead of the game period!
\nMaybe one day when I have time I\'ll redesign them and add some upgrades. For now people are still buying them and thats the only reason I make them..And also the only reason I ever started selling them\r\n
\r\n \r\n Ya sorry Johnny,my opinion is pretty harsh I guess but dont mean to knock your stuff so hard coz your right,your stays are WAY better than stock,and the stock setup is JUNK,and in that period,your right there was no other alternative.\r\n
I didnt expect it to be the best or one of the best stays for as long as it did honestly...As I have not made one change to it since 04/05...
\nAnd above all you have to consider what people were getting for $250 back in those days...
\nThis! And that is the only reason I made one, from the day I posted pictures of the 1st one I made for myself on SL, I was basically begged by the stunt community to start selling them...
\nIm glad that although I dont like steel parts personally, stealthstay product is a hell of a lot better then what was available back in those days... Stunt parts in general have come a long way...\r\n
\r\n \r\n My Johnny P Stay ROCKS and I spread the word to everyone
\nAnd NO it wasnt free
\nI wish I had better contact info for him when I made this "How To" video
\n\r\n
\r\n \r\n This bike is my first full fairing bike and is supported by the johnny p stay. Cant beat it with a stick. I have seen the stealth stays in person but I honestly prefer the johnny p.\r\n
