Less than 1 minute ago
\r\n \r\n front axel is coming loose just happened to my buddy last time at the lot. check that.\r\n
brake/fork issue
\r\n \r\n If it isnt the above, your left fork could be leaking oil and is running low. The less oil, the easier for the fork to compress. U could test it by taking the front wheel off and pulling each fork up and see if the 1 is much easier\r\n
\r\n I beleive he is asking about his 50 and if so there is no oil just spring and grease. it either your axel is a little loose or maybe the your fork leg is sitting a little crooked. check the axel and if its not loose at all take the front wheel off and see if your fork legs are crooked or sitting straight.\r\n
\r\n \r\n had same problem gota tighting up the front axle.\r\n
\r\n No oil in the forks! =O WTF! That\'s fucked up! Havent ever had a 50, but all the 110/125 pit bikes i\'ve owned (normal and upside down forks) have all had normal forks with oil in them lol. How do those forks hold up?\r\n
\r\n \r\n your fork bushings gone its common on the brake side\r\n
\r\n \r\n get derlin bushings and problem solved..\r\n
\r\n \r\n yeah get a set of 50 stunt delrin bushings ... a must if you wanna try doin stoppies on thoes little things\r\n
10-17-2011, 10:56 AM
idk if its normal and im just realizing it now or if ive got a fixable problem but when i grab my front brake at any pressure my wheel violently jerks sideways to the brake side....anyone?
« Next Oldest | Next Newest »
