Threads: 11
Hey ppl,
I'm keen to setup my pitbike with rear disk brakes with a handbrake, without paying outta my ass for these superbike conversion kits that go onto the master cylinder. I was wondering, would a scooter/quad rear hand brake system not work just fine? Otherwise a front brake system with an extended brake line, with the lever/cylinder upside down on the left side of the handlebars.
Any ideas appreciated
Thanx
Threads: 8
BirDMaN420
Hey ppl,
Thanx
I would try a cable to move the rear brake pedal. You could rig a mount to hold it. It might work? hydraulic gets expensive quick. a junction style handbrake should work plenty good on a pitbike also, you need a real small master, like a 12mm.
Threads: 19
anyone ever try to make like a mountain bike disc brake setup on a fiddy? im just wondering if that would be enough power to slow it down idk how strong those setups perform.
Threads: 8
*MeatballStunts*
I have used one, the back brake was insane as a handbrake. it was hard to use.
Let me post pictures of my set up when I get home. I have a rear disc set up on my 50.
I paid way more than I should have I think but I have to tell you it works amazing! I just wish I had a foot brake as I have it set up as a hand brake only.
Right now I am using a 2003 636 front master with a CRG lever with a steal braided line running to a chep O caliper off a pit bike.
Pics when I get home.
Threads: 39
Get a pitster pro? They come stock with disc front/rear.
Threads: 11
buddy lenzin
Pics would be awesome! I was thinking of trying to mod 2 brackets onto the back so they are independent, 1 for foot, 1 for hand. Have seen pics of that before.
2003 636 front master - is that an upside down front brake cylinder placed on the left side of the bars? I guess the pics will clear that up for me. So i take it the front brake system being converted to be used on the rear would work then??
Just need a longer brake line
@Ryan Moore, i'm not sure what a junction style handbrake is? Is that the conversion guys do on their rear cylinder where the front brake comes into the cylinder from the side?
@loogie the bike does have disc brakes front and rear, i just want a hand brake for the rear
i got this and replaced the master cylinder with a 14mm radial.and made a bracket for both calipers to fit
http://www.pccmotor.com/atv-brake-as...709011009.html
does it work good? and pics!
Threads: 11
Yes that's exactly what i wanna do! does it work nice? would u mind posting pics please?? Or a link to pics
"replaced the master cylinder with a 14mm radial." - pics of that especially since i have no idea what that means, and the brackets
