s10 help!!!!!
s10 help!!!!!
\r\n \r\n Try a wiggle test on the plug that goes to the alternator..my 93 ranger everynow and then does the same thing and it just my plug.double check wires... check batterys terminals...if not possible a bad battery gauge.... does the car act different when the voltage drops? battery is how old?? also when you had it tested it probably wasnt in the vehicle so their could possible be a cracked plate in the battery that when u hit the right bump take the right turn etc... it could case the plate to shift and cause you low voltage.. more information would help thanks GL\r\n
\r\n \r\n Is the voltage really dropping at the battery or the alternator? Or just dropping at the gauge in the cluster? Could just be a bad gauge or loose body ground causing the instrument cluster to act up???\r\n
\r\n Originally Posted by Dad\r\n View Post\r\n
Winner winner chicken dinner!\r\n
\r\n Originally Posted by 02gsxxr\r\n View Post\r\n
Try a wiggle test on the plug that goes to the alternator..my 93 ranger everynow and then does the same thing and it just my plug.double check wires... check batterys terminals...if not possible a bad battery gauge....does the car act different when the voltage drops? battery is how old?? also when you had it tested it probably wasnt in the vehicle so their could possible be a cracked plate in the battery that when u hit the right bump take the right turn etc... it could case the plate to shift and cause you low voltage.. more information would help thanks GL
And do your headlights dim if they don\'t that\'s another sign that it\'s the gauges\r\n
\r\n \r\n Alot of 2000+ g\'s have gauge cluster problems. Mostly in the full size but I have seen midsize with the same problem. Usually gas speedo and other gauges screw up as well.\r\n
\r\n \r\n tight grounds?\r\n
\r\n \r\n mine was doing the same thing (2002 s10) then the alternator went out\r\n
\r\n \r\n sounds like the regulator in the alternator, i had a 99 extreme do the same thing, this is how i fixed it......
\n\r\n
\r\n Originally Posted by dlish\r\n View Post\r\n
tight grounds?
MMmmmmm.... I Love Me some Tight Grounds!!!\r\n
\r\n \r\n i had a 4.3 that had two alternators shit the bed in one month. they kept testing good and eventually just died.\r\n
