Why does this 50 look weird!?
Found this 50 on craiglist and everything looks good except for some reason the forks look weird to me? He says they are BBR forks but they look super long and out of proportion or something? I wanna stunt it but idk if longer front fork will be a problem
It's Because He's got it on that bucket....
different front end
lol I mean I knew that was throwing it off a little but i swear my old fiddy didnt look this off
idk it looks raked out like a chopper
If you go to look at this make sure you check the neck of the frame out real good. on my 50 the stock frame was starting to buckle little by little. I used to measure with how many fingers I could fit between the skid plate and the front tire. after a month I could fit my whole hand in there and decided to get the billet ware cradle frame.
It almost looks like the frame is starting to buckle hence the chopper/raked out look.
Quote Originally Posted by oemsrt4
Good Call...
Thanks man, ya it looks like this bike has taken a few to many flat landings
The angle does look off. And the forks look long
You act like your gonna be using the front wheel alot.
