01 F4i ECU Reset?
01 F4i ECU Reset?
\r\n \r\n Your stock ecu, should make adjustments in your air fuel ratio up to a 10% change. I have never heard of a reset for stock ecu\'s, I could be wrong though. If you just have exhaust and maybe an air filter, you should be fine, worst ive ever seen was a bike running slightly lean, but it had more mods than just a pipe... download the service manual, tons of links around here to get one...\r\n
Does anyone know how to reset the ECU on an 01 F4i. Just got an exhaust system and figured it might be good to reset everything back.
