Threads: 19
Just got my go pro in today and im reading the directions about the settings.... what is everybody using... the 960p tallest hd video or the 1080p full hd highest resolution?
and can someone explain what the difference is this stuff confuses me i just want to shoot good videos and pictures lol
Threads: 3
Im pretty sure, if you set it to use 60 frames per second at 720p. it records better then at 1080 an i think at 30 frames ps. I could be wrong but that's just what I've read.
Ill see if I can find a video to show what I mean.
Threads: 12
Threads: 19
the whole 720 at something fps and 960 and 1080 confuses me and idk what the difference is
Threads: 66
from gopro
r1 Wide Angle Standard Definition 16:9 WVGA (848x480) 60 when smaller file size is desired
r2 Widest HD Video 16:9 @ 30 fps 720p (1280 x 720) 30 when mounting on vehicles or gear, when a very wide angle is desired but vertical viewing area is not as important
r3 Widest HD Video 16:9 @ 60 fps 720p (1280 x 720) 60 same as r2 but with ultra slow motion playback
r4(default resolution) Tallest HD Video Max Overall View 4:3 960p (1280 x 960) 30 when mounting on your body, helmet, surfboard or chest harness, this mode offers the most vertical viewing area of all resolutions
r5 Full HD Highest Resolution 16:9 1080p (1920x1080) 30 when vehicle or gear mounted, best choice for highest quality in-car filming. 25% narrower field of view (127�) compared to 170� view of other resolutions
To simplify that...
r2 for 720p(youtube stuff)
r5 for 1080p
r3 for slow motion stuff...
Threads: 66
r4Tallest HD Video Max Overall View
I never use this one. I guess it works for some helmet shots but doesn't blend all that well when mixing footage with other camera's
Threads: 19
thanks ross but what is better to shoot in 1080 or 720? if i do it in 1080 for better quality, is it easy to convert to 720 to be able to upload to youtube? or vimeo?
Threads: 3
Threads: 66
SICK pics btw cote!
Threads: 66
30fps for regular filming 60fps for slowmo stuff
Usually when filming you'll know how you plan on using the footage. If your mixing with DSLR footage or a nice shooter the 1080 will work great and worth killing the extra storage.
I usually keep it on 720 cause you can fit more on a card. I run a 32gig card in mine especially for timelapse and streetride stuff, just let it roll.
