01-05-2011, 08:36 PM
I got some 08 forks/triples and threw them on my 04, the issue I ran into is that the 07-08 stem is shorter than the 03-04.. not quite sure how much as I didn't measure it. Had to subtract a locknut because there's not enough thread due to it being shorter. Anyways my question is should I have my 04 stem pressed into the new lower triple so I can use the newer top triple or is it safe to leave it as is. I figure as long as I have the locknut and top triple bolt tight then there shouldn't be an issue
